Threads: 2
13 in 7 posts
Likes Given: 21
97
I'm curious why builders would still solder PL-259 connectors when crimp connectors are stronger and make a better connection? A crimp connector is not much more cost wise and the price of a hex crimp tool is not a lot of money.
I have a few crimp tools with different dies for different cable sizes. If anyone wants to borrow a set, let me know.
73 Rob
Threads: 168
25 in 20 posts
Likes Given: 65
520
I agree that crimping provides a better solution for cable connectors. Rather than relying on opinion, there are also engineering studies to support crimp connectors (see below). Each to their own and after seeing both soldered and crimped, but I prefer the durability of the crimped connections on the shield. It is positively a more positive connection...
Engineering studies have confirmed that the absolute best RF connections for double-shielded cables like LMR-400 and DXE-400MAX are made by crimping the shield, not soldering. However, most PL-259 crimped center pins aren't large enough and don't have enough contact area, which affects reliability. DX Engineering has solved those issues with these custom-designed connectors that we introduced on DX Engineering DX Series Coaxial Cable Assemblies. These PL-259s have soldered center pins that are full length and full diameter, so they connect properly, even with worn SO-239s.
Threads: 2
13 in 7 posts
Likes Given: 21
97
I couldn't agree more too. I bought the DX Engineering kit and crimp all my RG-213 and LMR-400 connectors from DX but I still solder the centre pin.
Threads: 31
46 in 38 posts
Likes Given: 6
483
My opinion IS an engineering study ;-)
Threads: 31
46 in 38 posts
Likes Given: 6
483
Another novel PL259 installation method I just read: (I don't have a picture)
The author exposes a large portion of braid & trims the dielectric back. He combs the braid back over the outer jacket, and screws the connector body over that. He then solders the center pin. He says it takes a couple pair of pliers to screw the connector on & he's never had a failure in 45 years.
A commercial crimp connector is superior because it traps the braid between the knurled connector body and the ferrule. This guy's method squeezes the braid against the coax itself, which is not nearly as rigid. It does sound better than the 4 little dots of solder method though.
Threads: 2
13 in 7 posts
Likes Given: 21
97
Although I've never tried it, I've watched the demo and have a solder pot if I ever try it. You tin the braid first, then trim the dialectric back. Instead of trying to flow the solder with flux through the four holes, the tinned braid will solder itself though the solder holes.
I had to make up 6 RG-213 patch cords this afternoon. I use the DX engineering strip tool and their crimping kit. Even after soldering the centre pin, I don't think I spent more than one hour for all 12 connectors.
Threads: 31
46 in 38 posts
Likes Given: 6
483
2022-03-23, 10:51:11
(This post was last modified: 2022-03-23, 10:52:48 by
Dave_VE3WI.)
I tried tinning the braid once, but I used too much solder & couldn't get the coax into the connector.
I had trouble using the DXE crimp tool on the large coax - couldn't squeeze it hard enough. I got a Times Microwave crimp tool which has better mechanical advantage. The DXE one works great on RG8X. There is an adjustment on the tool, one of those days I'll play with it & see if I can get it working better on RG8.
I put some connectors on LDF4 Heliax, you just need a couple of wrenches for those!
Threads: 31
46 in 38 posts
Likes Given: 6
483
I have an MFJ-941D that has been on various shelves for a long time. Worked well when I was using it. It has the old-style SWR meter where you set forward power to 100% then switch to reflected to read SWR (newer version 941E has the crossed-needle meter). The paint on the case is messed up a bit but I think it's clean inside.
If you want, you can try it out for him and see if it would meet his needs. Price would be whatever you think is fair, if it helps him get on the air. Money can be donated to GBARC.
Let me know.
Threads: 31
46 in 38 posts
Likes Given: 6
483
OK Hope he gets on the air & enjoys it
Threads: 2
13 in 7 posts
Likes Given: 21
97
Dave, do you know anyone with some 1/2" Heliax for sale? I have about 60' but need 170'. I don't mind splicing 2 or 3 pieces.
Thanks,
73 Rob
