  • 1 Vote(s) - 5 Average
The workings of a 4 Bay Dipole antenna
The attachment file is the Feb 09/2021 GBARC technical presentation.  The antenna I took apart was a 4 bay 70cm was the main soucre of photos and reference for the presentation.  The 4 bay unit did not have any 1/4 wave matching coax in the grounded feed arm of the folded dipole.  The 1/4 matching coax of a different impedance is used to make the antenna once completed a 50 ohm device.  Would probably be needed for the 2 bay or 1 bay antenna.  As part of phasing a multiple bay antenna, matching coax of different impedance may be needed but was not used on the reference 4 bay 70cm unit I used.
From the questions and follow-up emails, the info presented about the 4 bay diople appeared to be of great interest to those present.  I know for me it changed the way I thought how they were made.  If you were not there, you may find this interesting as well.
Cheers
Frank
VA3-GUF / VE0-GUF / VE0-VET
.pdf The workings of a 4-Bay Dipole antenna.pdf Size: 1.76 MB  Downloads: 22
Frank, SORRY,, But ,, as a retired RF engineer with over 50 years experience in the broadcast and communications industries, and a 60+ year active radio amateur,  I feel qualified to comment on erroneous claims and statements made in your recent presentation on 4 Bay dipole antennas..  I am very familiar with these antennas,  especially the Sinclair Radio products   (SRL)  designed and manufactured in Maple Ontario since about 1955.. I worked with the Sinclair engineers in 1975 to design and build special 2 bay  VHF and UHF  antennas for the CN Tower broadcasters..
Firstly you stated,, “The 4 bay unit did not have any 1/4 wave matching coax - - - - - - - “
Impossible ..... Each dipole , whether it is fed singularly, or as part of an array has a 50 Ohm coaxial feed point (cable), yet the centre feed point of a folded dipole element is 300 Ohms. The 50 to 300 impedance transition is achieved by connecting a 1/4 wavelength section of 125 Ohm cable in series with the 50 ohm “tail” and sliding it inside the outer tubing of the radiator just above the feed point..  It would not be visible to you unless you pulled the cable assembly out of the dipole or cut the aluminum tubing  (dipole)  open..
Why 125 Ohms? The standard formula for determining the impedance is the SquareRoot of the product of the two impedances.. ( SquareRoot of (300 x 50 ) = 122.474 ( nearest available value = 125 Ohms).. And,, to determine the physical length we must remember that this is 1/4 wavelength in
coax,  NOT free space so the wavelength calculated by the familiar formula (468 / F..mhz) must be corrected by applying the Velocity Factor of the cable...
Secondly,, You said “The 1/4 matching coax ---------- would probably be needed for 2 bay or 1 bay ------ but was not used on the 4 bay ---.”
Not really correct,,, The 1 bay antenna will not require any addtional matching because it is already a 50 Ohm antenna... But all the multi element, 2, 4 or 8 bays systems absolutely will.. For example if you connect 2 dipoles for a 2 bay system you will have to match 50/2 = 25 Ohms back up to 50 Ohms with a 1/4 wavelength piece of 35 Ohm cable..  ( cable impedance and length again determined as above)   The 4 and 8 bay arrays are even more complex.
Hope this helps sort out some of the confusion that seems to be out there amongst the members. I could go on,,   but enough for now....
73 de Paul,, VE3PQ
(2021-02-11, 15:30:47)VE3PQ  Paul Wrote:  Frank, SORRY,, But ,, as a retired RF engineer with over 50 years experience in the broadcast and communications industries, and a 60+ year active radio amateur,  I feel qualified to comment on erroneous claims and statements made in your recent presentation on 4 Bay dipole antennas..  I am very familiar with these antennas,  especially the Sinclair Radio products   (SRL)  designed and manufactured in Maple Ontario since about 1955.. I worked with the Sinclair engineers in 1975 to design and build special 2 bay  VHF and UHF  antennas for the CN Tower broadcasters..
73 de Paul,, VE3PQ
Thank you Paul for the additional clarifications and time to provide this info, much appreciated.
I was wondering if you could share your thoughts on the attached photo of the wires taken from the grounded side of the 70cm antenna and how they relate to the matching requirement.  My thoughts are the tube is most likely acting like a shield in this case for both the wire types shown in the photo.  The red arrow is where the red point of the wire was soldered to the cable feeding the antenna inside the tube.  The insulated wire from the red point, appears it might be unshielded 7 strand core RG213 till the black points, where it is connected to a tube insulated single strand core (slightly less than 1mm, may be .75mm to .8mm diameter) with air gap spacing done by a plastic spiral.  This single wire core portion is 11.5cm long inside the insulating tube and sits entirely inside the grounded side of the antenna tubing.
If this following additional info is relevant in your thoughts, the entire antenna cabling including the phasing portions up to the offset end is RG213 cable (red arrow connection).  Any info you provide would help the members better understand some of the techniques used to make these antenna and claify further details on their make-up.
Cheers
Frank
.jpg 4 Bay grounded side inside wire snip.JPG Size: 50.38 KB  Downloads: 42
73 de Paul,, VE3PQ
Cheers
Frank
Hi  Frank
It looks like you have managed to pull the inner conductor (and dielectric) of the coax out of the aluminum tube leaving the coax shield and
PVC jacket still inside...      Its probably stuck in there pretty well after many years of baking in the sun...
The section from the red-dot at the bottom of the photo, up to the 2 black dots near upper right will be part of the  RG213  (50 Ohm) feeder.               The transition (splice) to the 1/4 wave matching section is at the “black dots”.  So from the black dots to point A(1) is 125 Ohm impedance which  connects to the solder lug on the end of the aluminum tubing (point A(2).. This is the exitation point of the dipole element..  The braided shield
of the combination 50 Ohm / 125 Ohm assembly,,  (which I assume is still inside the aluminum tubing)  will be connected to the tip of the tubing
at the right side of the gap.  The gap is then covered / re-inforced with a length of plastic tubing and weatherproofed with heat-shrink sealer..
The aluminum tubing is not a shield..   It is the active radiator of the centre-fed folded dipole element...  The middle of the side opposite the
feedpoint  (where the support pipe attaches)  can be grounded without any affect on the radiation pattern as it is a zero voltage point.
Hope this makes sense  !!!      73,  P....
(2021-02-11, 08:19:39)VA3-GUF-Frank Wrote:  The attachment file is the Feb 09/2021 GBARC technical presentation.  The antenna I took apart was a 4 bay 70cm was the main soucre of photos and reference for the presentation.  The 4 bay unit did not have any 1/4 wave matching coax in the grounded feed arm of the folded dipole.  The 1/4 matching coax of a different impedance is used to make the antenna once completed a 50 ohm device.  Would probably be needed for the 2 bay or 1 bay antenna.  As part of phasing a multiple bay antenna, matching coax of different impedance may be needed but was not used on the reference 4 bay 70cm unit I used.
Cheers
Frank
Hi Frank it is normal that the PDF is truncated on the right of each pages..  It seem i am missing some stuff on many pages..
[Image: image.png]
73, de Daniel VA2DG
Cheers
Frank
Hey Frank can you double check the PDF document you have presented for the folded dipole i just downloaded it Still all the page are trunkated on the right we are missing all the info.
thanks
Daniel VA2DG
73, de Daniel VA2DG
Users browsing this thread: 2 Guest(s)
