Keen to make your own repeater?
Construction projects, kit building, ideas. looking for that hard to find part?
x 8
Post by va3ts » Sat May 20, 2017 6:46 pm
Try this, open repeater for the raspberry pi.
https://openrepeater.com/
Ya but I don't have my advanced qual.... strickly speaking a repeater is assumed to be remotely controlled, in other words if this is a radio at your QTH, and you didn't build or modify the transmitter, then you as a holder of the basic qual can experiment as you like. However, if you leave your QTH, you must turn off the repeater.
x 8
Portable Repeater Controller
Post by va3ts » Mon Jul 31, 2017 1:52 pm
This microprocessor-based Portable Repeater Controller was designed to quickly build a fully functional repeater 'in the field' in less than no time. Due to its universal design it can be used all the way from classroom instruction to 24/7 repeater operation. A fully functional amateur radio repeater system is created by just connecting two radios, an antenna, a power supply and optionally filters.
http://shop.emco-electronics.nl/portabl ... oller.html
