SWR Indicator for balanced line
Questions and solutions about your antenna and feedline projects.
VE3PCP
x 6
x 6
Post by VE3PCP » Sat Sep 30, 2017 12:11 pm
Hi:
Many years ago I made one of these and it worked very well as a basic indicator of SWR on 300 ohm twin lead which I have used for many antennas over the years.
I just taped it to my feed line right after the tuner so I could see it from my seated position while operating.
Not sure how many of you use balanced line but here is a link to the article about how it works and how to build one.
Enjoy!
Rob
VE3PCP
http://www.rfcafe.com/references/qst/tw ... r-1947.htm
VE3PCP
x 6
x 6
Re: SWR Indicator for balanced line
Post by VE3PCP » Sun Oct 01, 2017 11:38 am
I rebuilt my unit yesterday and did up a short video to explain it and show it in operation.
Enjoy!
[BBvideo=560,315]https://youtu.be/TBWElwXIBXU[/BBvideo]
x 8
x 5
Post by va3ts » Sat Oct 21, 2017 2:31 am
Some history and theory on open wire feeder and swr
[BBvideo=560,315]https://youtu.be/w1eE13UXAKs[/BBvideo]
open line - spacing usually < 1% of the wavelength
When the line length is an even multiple of wavelength/2 , the input resistance is equal to the load resistance, regarless of line Zo.
The characteristic impedance of air insulated parallel conductor line
Zo=276 log 2s/d where s = center to center distance d = outer diameter of conductor
