Page 1 of 1
40-m-compact-4-square-antenna
Posted: Sat May 20, 2017 10:17 am
by va3ts
40-m-compact-4-square-antenna-ea5avl-11.pdf
Re: 40-m-compact-4-square-antenna
Posted: Mon Sep 18, 2017 1:48 pm
by ve3efq
Giving this a read now; I was looking into building a phased array for 20m using the same type of light wire I made my dipole out of, an array that could be part of a portable set up; never built an array before though and I was going to make a post in the forum about arrays when I saw this write up about the 40m 4-square.
Looks like there can be a good increase in multiple directions with a phased array and a relay. I only started reading about these last night - I was thinking such a system could be use for directivity rather than a yagi - which would be hard to suspend up high up in the trees in my camp let alone rotate it around around.
I did at one time build a sloping two element, single band yagi that worked ok (based upon ideas given in this article: http://www.arrl.org/files/file/Technolo ... 111035.pdf).
'EFQ
