How to Use an SWR / VSWR Meter
Questions and solutions about your antenna and feedline projects.
ve3wrf
x 10
x 2
Post by ve3wrf » Thu Sep 06, 2018 12:05 pm
VSWR, Voltage Standing Wave Ratio / SWR meters are very useful, and although easy to use, there are a few useful hints and tips that can be applied.
Useful article for all hams. Especially new hams, though this is a site we should all have bookmarked for lots of other great articles.
https://www.electronics-notes.com/artic ... -meter.php
Doug / VE3WRF
1 x
VE3PCP
x 8
x 11
Re: How to Use an SWR / VSWR Meter
Post by VE3PCP » Fri Sep 07, 2018 3:52 pm
Here is a combination SWR bridge and watt meter that I recently acquired.
Requires 12VDC to make it work.
Once you have that, it does all the work. No adjustments required.
I tested in inline with one of my other SWR bridges and it seems to match what it said.
You do not have the required permissions to view the files attached to this post.
