On-line antenna calculator
ve3wrf
x 10
x 2
Post by ve3wrf » Tue Jul 24, 2018 11:23 am
New (and old) hams might find this antenna calculator useful when making their own antennas.
http://www.zolalab.com.br/wavecalc.php
Doug / VE3WRF
VE3WI
x 2
Re: On-line antenna calculator
Post by VE3WI » Wed Jul 25, 2018 4:06 pm
This can save a bunch of calculator punching. Thanks Doug.
Note that the 1/2 wave and 1/4 wave formulas have the 95% "K factor" that we typically use for wire antennas on HF, built in.
For VHF or UHF, a lot of antennas use tubing elements. That can make K significantly different from 95%, based on the length/diameter ratio of the elements. There are tables in the ARRL Handbook & Antenna Book, also on various sites online. Here's a link to a good write-up on "K" by Don, VA3DDN: http://hamguyparts.com/files/Download/Ecd_res.pdf
Lots of neat stuff on the Zola website. It would help to know Portuguese though :-)
