2025-07-08, 12:57:22
To all,
Is anyone interested in building with me an antenna lifting Cradle that would slide up and down the GBARC mobile tower similar to the photo below I found on Facebook?
![[Image: Antenna-Slider-Cradle-for-Mobile-Tower.jpg]](https://i.postimg.cc/F7Jjcbh3/Antenna-Slider-Cradle-for-Mobile-Tower.jpg)
This would make the tower available for more use/deployment without requiring me or another to climb the clubs mobile tower since the BEAM/YAGI would be mounted at ground level and then hoisted up. Comment to this post with queries, suggestions or interest in participating in one of the following steps;
Start general line drawing design from details seen in the photo
Proposing and designing enhancements
Final drawings of parts/assemblies to scale or with measurements
Itemizing metal lists and then pricing
Presenting to club membership project design, costs and proposed build timeline
Assembly
Testing and modifications if required
Write up mounting and use instructions for proper antenna rotor alignment
Assisting with assembly at Field Day
I would even suggest if at all possible with the group that gets involved to duscuss if the current mobile tower could be extended to raise the antenna higher when deployed.
Looking forward to hearing from you.
Assembly
Cheers
Frank
Grey County ACS/ARES Co-ordinator
VA3-GUF / VE0-GUF / VE0-VET
Frank
![[Image: gbarctowerplate-0003.jpg]](https://i.postimg.cc/jLqycmxd/gbarctowerplate-0003.jpg)
